Not sure if scheduled scan is running
Hello, John
The "last computer scan" status on AVG interface will update if you start the scan only only by clicking on "Scan computer" button on the dashboard. It does not update for any other scan. Regarding the schedule scan, you will receive a notification from AVG tray icon when the scan is started. If you miss it, please change the schedule scan timer to 5 minutes away from your current time and check if it is starting. If the scan starts correctly, you can be assured that it is working fine.
Hello,
I have a weekly scan set up to run on my computer.  I have the free version of AVG (18.4.3056).  How do I tell if the scheduled scan has run.  The dashboard says my last scan was 2 months ago.  When I set up the scheduled scan I stated I wanted a report about it, but I don't know where to find those.  Thanks.
Hello, John
