Hello John.
Thank you for contacting AVG Support Community.
We regret the inconvenience this may have caused.
We will certainly check and help you.
It seems that you have not activated the program yet. Please activate AVG TuneUp using the steps in the below article.
https://support.avg.com/SupportArticleView?urlname=activate-avg-tuneup
To locate your activation code, please refer to the below article.
https://support.avg.com/SupportArticleView?l=en&urlname=Locate-AVG-Activation-Code#:~:text=Go%20to%20My%20AVG%20%E2%96%B8,is%20visible%20next%20to%20Subscription
After activating the program, please check if you are able to fix the issues shown in the maintenance scan.
I just paid for, downloaded, installed and ran TuneUp. After running the app, it said I had 2000+ maintenance fixes. So I click "fix"…and a screen pops up that says I have to pay even more. So, as far as I can tell, I'm paying for an app that tells me I have a bunch of fixes but it won't fix them. Am I missing something? What good is the app if it doesn't resolve issues?
Hello John.
