Offline installer for infected system
Karon,
We apologize, unfortunately, we do not have offline installer for AVG Free Antivirus program. We request you to uninstall the older version of AVG using our remover tool http://avgclick.me/UninstallAVGAV. Kindly download your AVG remover and run it, then go to C: -> AVG Remover -> Bin -> pctremover.exe and avgfmwremover.exe (do not restart your device if prompted), then run avgremover.exe (it will automatically reboot your device).
Then please remove the AVG folders manually as suggested below. Go to Run window (press windows key and R key simultaneously) and type the following comments to delete the folders.
1. Type  “Temp” and press enter, remove all the files.
2.  “%temp%” and remove all the files.
3.  %appdata% - Remove all the AVG folders.
4.  %programdata% - Open the AVG folder and remove the old files.
My computer was infected by something a few days ago that locked my browser with a warning screen and a voice telling me to call a number.  I restarted the computer and it came back.  So I then went to the menu button and it worked so I cleared the history and reset my homepage.  The browser now loads very slowly so I ran numerous anti virus programs.  Nothing was found.  I then downloaded Malwarebytes complete and tried to install it after suggestions in forums.  It will not install and gives me a Runtime Error.  I cannot disable my AVG 2015 because there is no taskbar icon.  The AVG main screen doesn't list a Temporarly disable AVG".  I then ran MWB-clean, ADWCleaner and Zoek scanner.  Redownloaded MWB latest and an older version.  Both give same error when installing as Admin.  I don't want to be online as Admin. because I don't know what the virus my be doing.  I cannot find a way to get AVG 2016 full download on the web directly from AVG.  There are other sites claiming to have it but I'm suspicious.  I want to put it on a flash drive using another computer and then install it on my infected computer.
Any suggestions on how to get AVG onto my flash drive so I don't need the internet?
Also, any general suggestions to fix my virus problem?
Karon,
Please go to c: drive-> program files and delete the AVG files and download your AVG program from our official site: http://www.avg.com/us-en/download. Then initiate the scan, check for threats, remove unknown extensions and uninstall unwanted programs from control panel.
Please feel free to get back to us for any issues with AVG. Thank you!
