Hello Gordon. I request you to be specific about the issue that you face to assist you further. Thank you.
scan shows 1 hard drive heavily defragmented but will not clear shows each time scan
Hello Gordon. Based on the usage of the disk the alignment changes every time and during the next scan you will notice the changes that you have modified recently as the result. So, there is nothing wrong if the size vary during each scan and shows you the different value. Thank you.
every time i use 1 click maintenance i get1 hard drive heavily defragmented it always clears but still there next time i use it
