The title, I think explains the problem.
I use AVG PC TuneUp and when I try to change Windows settings in the Opera section, it says that Opera is not installed, but it is installed (version 47.0.2631.55 (PGO)).
Internet Explorer and Mozilla Firefox installations are correctly detected.
I tried to uninstall and reinstall it with no luck.
Any suggestions???
Thanks for clarifying the situation.
It would be nice though to gray out the options for firefox and opera in they are not installed or supported as the program do so in browser data dialog box.![]()
Panagiotis,
Thank you for your patience. Please be informed that setting is for old versions of Opera (v. 12 and older). The new versions are based on Chromium and for that, same as for Chrome, no settings are available. We will take this as your feedback and pass it up to concern team.
Panagiotis,
Thank you for your feedback, Panagiotis. It will fix it in the upcoming updates.
