Passwords deleted after using Tuneup
Hello Thomas,
We understand that your passwords got deleted after using AVG TuneUp.
We're sorry to know that.
However, we'd like to clarify that usually, AVG TuneUp will not deal with the passwords stored on your browser.
It deals with the cookies, caches, browsing history alone to enhance the browser's performance.
From your description, we're uncertain about the password option which you've excluded. Please share us the screenshot of it for better clarity.
Meanwhile, if you suspect that AVG TuneUp has caused the issue, you can revert the changes made by it.
To do so : Open AVG TuneUp - Rescue center (at right pane) - Click on undo beside recent changes & check.
Hello Thomas,
I can read that other users have had same problem.
All passwords are gone after using  Tuneup quick cleaning.
That is simply not acceptable
