I have AVG INternet Security. For the last couple of days, the passwords I have for the various websites I visit with Edge do not populate or offer to be saved, like before. I have used AVG for some time without issue. When I turn AVG off, the passwords will again populate.
I suspect it is a result of a recent update of AVG, or EDGE.
Anyone else seeing the issue?
Hello Chris,
We're sorry for the inconvenience caused. We'll look into this further.
Please write back to us in your own/new post, so that we can access your email address & send you an email with further instructions.
Kindly click on the "Ask the community" button to create a new post.
Then, type in your topic, issue description & proceed with posting your query.
Thank you for understanding.
Hello Jeffrey,
We will check and help you to resolve it.
- Have you tried to disable AVG Internet Security components one by one and check it?
- Have you tried reset Edge browser and check the status?
- Please confirm the operating system installed in it.
- Refer the following link to know how to disable AVG components (https://support.avg.com/SupportArticleView?urlname=Disable-AVG-Antivirus)
I'm having the same issue. I have followed all the steps above and and still having the issue.
Repairing AVG installation did not corect the issue.
If I disable Password Protection In AVG the passwords will again populate. (Disable Password protection. Close Browser, then restart browser Microsoft Edge Ver 95.0.1020.53) I am Using Windows 10 Home Ver 21H1 Build 19043.1348. Is this normal behavior? It was not occuring before, and I did not knowingly enable more components of AVG.
Thank you for writing back to us, Jeffrey.
Let's repair your AVG Internet Security & check if the issue persists.
Refer to this article to repair your AVG Internet Security.
Keep us updated.
Please accept our apologies, Jeffrey.
To further investigate this issue & help you resolve it, we've sent you an email with detailed instructions to contact our additional support.
Please check your inbox/spam folders to find the email and use it to contact them.
