PC Tune up Defragmentation - is there a way to interrupt or use less memoy
I just installed AVG Ultra and the last task the PC Tune up is running is Disk Fragmentation.
Not sure how long that should take, but this has been running about 14 hours now, on a 2.85 GB hard drive. This process is using about 75% of the memory, making the computer difficult to do normal work with. I don't want to shut it down and risk damaging any files…I am wondering if there is a way to either Pause the Defrag processes, or else change the setting to have a lower priority on resource use.
Thank you in advance
I don't see anyplace in the settings where I can indicate which drives I want defragged. I looked at every tab in the settings. Can you please tell me how to access this?
Hello Danny,
If it is a less capacity hard disk (as per size) you are using, you can skip the defragmentation task from the maintenance scan. To do so, follow the steps below:
Open AVG PC Tuneup and click on Settings.
Then select "AVG 1-click maintenance" in the left pane menu.
Then you should see the maintenance tasks listed on your right side.
Please uncheck Disk defragmentation to skip that task from the scan.
Please, feel free to let us know if you require any further assistance. Thank you.
Hello Danny,
We understand how something like this can really try your patience.
Could you please confirm whether you have set up the disk fragmentation for external hard disk? so that we can assist you better.
Hello Danny,
