Pc tune up does not work
Wim, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
pc tune up is again not working
Wim
the avg pc tune up does not work on my laptop
also google chrome does not work
and windows update does not work also
Hello Wim,
We are sorry to know that the AVG PC TuneUp does not work in your computer. To assist you better, could you please let us know the exact error message you get when you try to open the AVG PC TuneUp? Please send us the screenshot of the error message http://avgclick.me/getscreenshot.
Thank you
Hello Wim,
Thank you for the information. We suggest you to run repair of AVG PC TuneUp and see if that fix the issue. Please click on this link for the steps to run AVG repair avgclick.me/RepairAVG.
Thank you
Hello Wim,
It seems that our senior technician's are still working on your case and once they have completely analyzed the issue they will reply back to you via email as soon as possible.
Wim
Hello Wim,
We are sorry to know that the issue persists. In this case, we will email you a link to collect error logs from your computer. Please run the same and we will analyse the logs and soon contact you with the solution.
Thank you
there is no error message if i click the button nothing happens
Hello
Your collega from advanced support was able to repair some of the issues.
However after i restarted the laptop all the problems were back…
Hello,
i have followed the instructions but without sucsess.
I have run a repair on "AVG" on "AVG PC Tune up"  and on "AVG Protection" after every repair i have rebooted the laptop and try to run PC Tune up but without result.
Also google crome and windows update are stol not working
Wim
