Pc tune up problem
I have the same Problem, Uninstall TuneUP 2014 not possible and Install TuneUP 2015 not possible. The newest uninstall Tool with Reboot do nothing. Error 1612, 1603, C:\WINDOWS\Installer{A996C182-3724-4DF1-A4BC-66154FE57DFE}\Lang_de-DE.msi. Clientprozess-ID: 8304.
And Error 1714 in eventlogs.
Hi Nitheish,
For help on your issue please try remove AVG TuneUp using this tool and than install latest version form our web back.
Martin, Previous availability posting will still apply but please bear in mind that it's now the weekend. Alternatively have a look @ this new form link (https://support.avg.com/support_contact_form) to get email/chat/phone support.
I can't install pc tune up in my pc.if i try to install it is showing
AVG PC TuneUp 2014 installation cancelled before completing
The AVG PC TuneUp 2014 installation was cancelled before completing due to an error.
your system was not modified.To install AVG PC TuneUP 2014 at a later time, please restart
the installation assistant.Click on the "Exit" button to close the assistant…
Help me plz
Hi Martin,
In order to analyze it please provide us with diagnostic output using this tool and please add detailed description of issue.
Hi Nitheish,
