Performance problem
what is the email for customer support so I can send the image
The process named "AVG Antivirus engine server" is using 94 to 95 percent of my cpu and I can't end the process, my computer crashes when I try to do anything else, is there a way to end the process?
Hello John,
We regret the inconvenience caused. We'll look into this and help you.
Please share us the screenshot of the "AVG Antivirus engine server" CPU process consumption, so that we can check and help you further.
Refer to this article to take a screenshot.
Thanks in advance.
You can share the screenshot in this post it self, John
Follow the steps in this article to capture the screenshot :
https://support.avg.com/SupportArticleView?urlname=AVG-Create-screenshot
I have sent you an email asking for the screenshot.
Please check your inbox/spam for the email.
And revert with the screenshot for further assistance.
Hello John,
Thanks in advance.
It's over one megabyte, it's 5.61
