Phase 0 Starting watchdog
Ash,
We appreicate your efforts, we apologize.  We would like to inform you that the issue is caused by outdated Logitech drivers and is unconnected with our software. This has been confirmed by Microsoft.  We request you to update or remove the Logitech drivers. We suggest you to contact the Microsoft support for further issues with this. Thank you for your better understanding.
Hi there, thanks for responding so fast, i dont have anything logitech related and when i uninstall avg the problem goes. i think this is a avg issue?
Hi there, im running into some problems with AVG and windows 10
everytime i reboot my pc i get the following messages for about three-four seconds;
PHASE 0
- starting watch dog initialization
- loading configuration( root kernel, set up)
- pre initialization events
- creating watch dog dynamic key list
- sub systems initialization
Then it just boots.
I've tried uninstalling using remover about 4-5 times now, system restore etc and nothing seems to work.
thanks in advanced
Ash,
Hello Ash,
We do understand your concern. As mentioned above Microsoft has confirmed that the issue can be caused only by the Logitech drivers. However please try to use the AVG rescue CD using the instructions on the article http://support.avg.com/SupportArticleView?urlname=How-to-use-AVG-Rescue-CD and check if it helps.
