Phone locked help!
Jere, Please note that this Community deals mainly with the technical queries regarding AVG Windows products. AVG Android support is provided through email only. Don't know if this will help?.. Have a look @ this article (http://avgclick.me/LockedPhone). Otherwise, Please click on the following link (http://avgclick.me/AVGtechnical) and fill out your details, select as Android then the name of AVG Program that you installed in your mobile and in description please completely explain about your issue and finally click on Email option. Also when filling out your details choose Yes for the Question "Are you currently using any paid/trial AVG products?" even though you may be using the Free version and fill out necessary details and click on Email option. The AVG mobile team will reply back to you via email with a resolution.
Hi, The software locked my phone. I deactivated my main sim card and the software locked my phone. I have dual sim phone. I can't activate the sim card because i can't open my phone… I don't remember my pin code to this software. There is not reset pin option on my locksreen. I need desperetely help… Phone is xperia z5 premium dual.
