PIN login problem
Hello Jan,
I apologize for the inconvenience this may have caused. Support for AVG android apps is provided through email only and I would request you to submit your query to our dedicated android support team for further assistance.
Open AVG Anti-virus app.
Tap on drawer.
Click on Help and support-> Contact support and fill the form.
Hi
I have had AVG installed on my Xperia phone for a long time
yersterday I used the oppurtunity to lock some apps in my android. So I entered a PIN code and locked AVG, chrome etc. Now the PIN doesnt work and Iknow its the correct one. Tried to Reset PIN but that doesnt work either. When I login here it says that I dont have any  devices, which means I cant changera PIN or unlock the apps from here. Any ideas what to do?
thanks
Hello Jan,
Tap on drawer.
Hello Avinash
Thanks for you help
unfortunately this doesnt help me since the AVG app is pin locked as well. So I cant open it. Do you have any more ideas?
thanks
Jan
Jan, Please note that AVG Android support is provided through email only.
Jan,
Please click on the following link ( http://avgclick.me/AVGtechnical ) and fill out your details, select as Android then the name of AVG Program that you installed in your mobile and in description please completely explain about your issue and finally click on Email option. The AVG mobile team will reply to you via email with a resolution.
