Please help error code 0xC0070643
I have ran the remover tool (run anyway), and removed everything AVG related from both drives, preformed fresh installs from both online, and offline versions. Still nothing… soooo…. I have installed Avast with no issues, love AVG but for now i'm just going to go with what works. I’ll try AVG again in a few years when i upgrade to a new laptop. Thanks for the effort but i'm throwing in the towel.
Hello I have used the uninstall tool about three times and everytime I reinstall I end up with the 0xC0070643 error code!! BTW I'm using a upto date version of windows 10, on a 64bit i5, asus laptop. If anyone could help I would consider you a hero… thanks.
Hello Bradley,
We  apologize for the inconvenience caused.
We have sent you an email instruction to get connected with our technical support team. Please follow those instructions to get in touch with them and you should be able to resolve your issue.
Ok so the uninstaller is not finding anything to uninstall… Lolz… also the unistaller is going to my downloads in D: my HHD and there is a AVG file in my C: SSD.
Bradley,
We certainly understand your concern.
In this case, we kindly request you to please run it "Anyway" and then try to install AVG Program as suggested in our previous post.
