Pop Up Notification Problem
Hello Brendon,
We request you to please repair your AVG Internet Security using the article avgclick.me/RepairAVG .
I have AVG I.S. 2016 & have system tray notifications enabled for all catagories. I assume this means a pop up box in the bottom right of my screen when something happens. However it doesn't seem to work at all.
I am running Windows 10 & this feature works for all my other programes/apps as required.
I have also noticed that when I disable notifications in advanced settings I get a user account message confirming this action, however this does not happen when I re-enable tray notications.
Any ideas please?
Thank you, but I have already tried that. It didn't make any difference.
Hello Brendon,
Hello Brendon,
We would request you to run AVG remover tool based on your OS (32-bit or 64-bit) to completely remove AVG and then re install it using the article http://avgclick.me/InstallAV .
To determine whether your OS is a 32-bit or 64-bit, please click on this link. http://support.microsoft.com/en-us/kb/827218
