Richard, For your info, just in case that you are unaware, you can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
I have a PreSonus USB audio interface used to record musical instruments and microphones. Whenever my computer sees this device is plugged in, I get this popup warning, which usually appears briefly and disappears repeatedly for a while, and then stops. Universal Control is the driver for this equipment.
Is my AVG protection involved with this in some way?
Richard, Your screenshot is actually visible on the Community!!
Thank you for providing screenshot Richard,
It seems the issue is not because of AVG. However, I request you to check if the issue is resolved when AVG protection is disabled? Right click on AVG system tray icon and toggle the On/Off slider to disable AVG protection.
Best regards,
Thanks. I was on the web tab. <SMH>
Hello Richard,
I understand that AVG is blocking this hard driver from installing in your computer. We are unable to view the screenshot you have attached, please resend the screenshot http://avgclick.me/getscreenshot. We will check the same and assist you further.
I have the screenshot, but don't know how to get it to you. I posted it on Facebook and put in a link, but evidently that did not work.
thank you for your reply.
I have the screenshot. How can I get it to you?
The hardware is shown here:
Discontinued Products – PreSonus
