after a recent update the forwarding parameters were wiped clean. I did enter them again (and the configuration is correct) but AVG does not forward/open them. AVG seems not to react to any port forwarding. when I turn AVG off the ports are open and work fine, but when AVG is on, it does block the ports.
Hi Arie,
This isn't the usual behavior.
To determine the exact issue, we would like to offer you a free remote support. We've sent you an e-mail instructions to connect with our remote technician to rectify this issue further. They will fix it completely or escalate it if needed.
If the e-mail is not found in your inbox, do check your spam/junk folders as well.
Hi Arie,
