Hello Mike,
We will check and work on it. We need to determine which component is blocking your access with Power Point. Open AVG Internet Security -> Menu -> Settings -> Components -> turn off each components and check with the status. Please share the screenshot http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot of error message you received to have better understanding.
Hello Mike,
Can not open power point attachments to emails received, comment received is that AVG may be blocking it, so I should switch off AVG then open the attachment then switch on AVG -anyone had a similar problem
