Printing Issue due to AVG message stating aborted connection
Hello Arlene,
We are aware of it and our developers are working hard to determine the exact cause. Could you share the screenshot of that popup with full path?
You can add chrome to AVG exception list and check if you could print your documents. Go to AVG Internet Security -> Menu -> Settings -> General -> to add your Exception list. Let us know if you are using trial version or paid version of AVG product.
I am getting the same pop-up report from AVG that others in the community have discussed and posted a copy of. When I try to print a document, the AVG screen comes up and says that the connection was aborted on update.googleapis.com with infected URL: phishing. I ran a scan and it says everything is okay, so I need help with what else I need to check to make sure nothing is infected and also how I can get AVG to allow my print connection to go through again. Until this is resolved, I can't print anything. Thank you for your help.
Hello Arlene,
