Hi R,
It doesn't seems to me AVG connected just tried it on my PC and it is not working even without PrivacyFix.
(I am not running AVG antivirus either.)
When I install/update DivX webplayer in Chrome, the congrats/success webpage runs a DivX movie trailer, but video is blocked. AVG needs to fix this. Where's "feedback" to let them know?
Hi R,
I meant DivX.
I can't help it if you can't run DivX... but don't just say 'not connected'.
I CAN run DivX vids in Chrome... I'm talking about the page that's auto-displayed when DivX is installed/finished. I CAN play -that- Divx vid in chrome with DivX installed, not with PrivacyFix enabled.
Chrome v34.0.1847.131 m and DivX player 10.2.0, build 11.3.2-34 Lazerev (not sure if that version is same for webplayer wherever that might be found).
With PrivacyFix enabled... all I get is sound, and yes, that webplayer error that you've seen.
Disable PrivacyFix and the vid and sound plays just fine.
Unfortunatelly I tested it on one more PC same result it is not working even without PrivacyFix. I understand that in your case it is working, but it is not possible to analyze it/fix it if it is not working at all.
