Pro features gone / samsung note 4
Syed, Please click on the following link (http://avgclick.me/AVGtechnical) and fill out your details, select as Android then the name of AVG Program that you installed in your mobile and in description please completely explain about your issue and finally click on Email option. The AVG mobile team will reply back to you via email with a resolution.
Hi there! This evening i have updated the software on my mobile and since then the pro features are gone. I have tried to check by logging in my account and no data is being reflected. Any help is appreciated.
Thanks in Advance.
