Problem 0xe001f94
Hello Arslan,
I understand the inconvenience caused, lets work together to fix this issue. Please check the AVG programs you have already installed (open control panel > programs and features) and also let us know which AVG PC TuneUp program you want to install (AVG PC TuneUp or AVG TuneUp - Unlimited). If possible, please share a screenshot of the error message to assist you further. You can check the following link to see the instructions about taking the screenshot (http://support.avg.com/SupportArticleView?urlname=How-to-create-a-screenshot). You can post the screenshot here in your topic. Click on 'Answer' & then click on the 'Image' [mountain symbol] & follow the instructions.
Best regards,
i can't install pc tuneup
Hello Arslan,
Best regards,
