Hello Andrew,
We will check and help you to resolve it.
Could you please confirm whether you are using AVG Business product or AVG Ultimate package?
We need to check whether firewall or any other AVG component blocking your email client.
Please follow the steps in this article (https://support.avg.com/SupportArticleView?urlname=Disable-AVG-Antivirus) to identify the AVG component that is causing the issue & let us know.
Thanks Sreenu - I will proceed via the link you kindly supplied.
I am trying and failiing to attach an EssentialPIM email client to a Winows server and although both ends work in standalone mode, connecting to the server fails. I'm sure this is a firewall configuration issue but I'm out of my depth about how to configure AVG to allow the connection to succeed.
I'm okay with the basics of IP addresses and ports - but figuring out how to configure the firewall on both client and server leads to confusion.
Connection Instructions
Any help about how and what to configure would be gratefully received.
Thanks!
Followng up on this…
I raised a support incident on the AVG business website two days ago, which hasn't been responded to. As part of that process the web siite advised that I would receive a follow up email advising the number of the support incident - which never arrived.
I'm really not ecstatic about AVG support. Their system knows all about me and the server as I regularly receive support emails about the server - sometimes advising that the server needs rebooting following an update.No complaints there - though raising a support incident leaves much to be desired.
My AVG support is up for renewal in a couple of months -and it looks like I'll be looking for an alternative.
Hello Andrew,
Hello Andrew,
We are sorry for the delay in response. We can really understand your frustation. We have made your request with highest priority. Our Business support team will get back to you as soon as possible. Thank you.
Hi Veeramani,
I am using AVG Business on the server, and Internet Security on the client.
I disabled AVG on the client – no change.
Are there log files which report firewall actiivity? At the momentI don't know where the failure to connect is blocked.
Regards,
Andrew
You are welcome, Andrew.
Trying to use the liink, but web server says busy and try again later.
