Problem during installation 0xef001f958
Hi Bodunrin,
I apologize for the inconvenience caused with the re installation. I have sent you an email instruction to get connected with our technical support team. Please follow those instructions to get in touch with them and you should be able to resolve your issue.
Hi, I tried reinstalling AVG antivirus. It keeps giving me the error code 0xef001f958 during installation. I have downloaded and installed the AVG remover tool and restarted my PC. But iot has still been impossible to re-install the software. Thanks
Hi Bodunrin,
