Hello Stephanie,
Are you trying to install the trial version of AVG Protection?
Could you please confirm the error code once so that we can assist you better?
May I know the operating system of your PC?
Hallo. I been traying to installing the AVG internet protection. the whole day and it keeps on giving me erron code 0xc0070783. what to do?
Hello Stephanie,
Hello Stephanie,
Thank you for providing the information. We would request you to run the AVG remover tool to remove all the remnants of the failed installation as described below. After you run the remover tool successfully, please download and reinstall AVG free.
To run remover tool, please visit http://www.avg.com/tools#tba2 and click on "AVG Remover" to download the remover tool and run it on your PC. It will ask you to select which product you would like to uninstall. Please select "AVG Protection" and follow the setup instructions to uninstall AVG. Once the tool is run, your PC will automatically reboots. After the restart, please check if a folder with name AVG Remover is created under C:\ and remove it.
Then please follow the steps in this article http://support.avg.com/SupportArticleView?urlname=Download-and-install-AVG-AntiVirus-Free to install AVG Anti Virus free.
