Problem on avg tuneup
Hello Giovanni,
We are sorry to know that you are unable to install AVG PC TuneUp.
This issue can happen if the old traces of AVG PC TuneUp is still present in your computer. Please go to control panel and see if older version of AVG PC TuneUp, if there is no other program, then you can try the installation using this link http://files-download.avg.com/inst/mp/AVG_Performance_803.exe
recalling my copy of avg tuneup bought me from the path error.
I called the email purchase the product and try to reinstall the program but the download says "unexpected error" code 0xe001f949.
at this point I tried avg remover but this gave 0x000012f error.
can you help me get out of this loop and reinstall avf tuneup.
the laptop I installed windous 10.
Thank you very much
Hello Giovanni,
