Bengt, When uninstalling McAfee did you download & run the total removal tool (http://us.mcafee.com/apps/supporttools/mcpr/mcpr.asp)?.
I uninstalled my former virus protection McAfee and then installed AVG. Since then, I will not access some web pages, such as ebay.com and svt.se (swedish television). I don't get it ... and it's the same problem with another computer in the family. We have Windows 10.
Sorry for the trouble, Bengt.
Have you installed trial version of AVG Internet Security? If so, open AVG Internet Security -> Menu at the top right -> Settings -> Components -> Enhanced firewall -> Customize -> System rules -> make sure all the task has been enabled.
Again, Firewall -> Customize -> Network Profiles -> change all the profiles from public to Private. These are the default settings recommended by AVG. Check whether your sites works fine. We are here if you need any help.
