Problem when reinstalling AVG 2014 antivirus
Hi Myriam, we apologize for the inconvenience caused. I understand your concern. I will send you an email with steps to get in touch with our technical team. Please follow the email instructions and get in touch with them. Our expert technicians will fix this issue for you. Please do not hesitate to get back to us for further assistance. Thank you.
Hello,
Meanwhile I did several tests.
I have a licence for AVG Antivirus 2014, valid till May, 2016. The
operating system is Windows 7. I do not have access to Google Chrome
nor Mozilla Firefox when AVG is installed om my computer.
For the moment, AVG is not installed at all otherwise I have no access
to internet.
I noticed that the problems occur on protecting the computer and my
identity. Internet is working while surfing and emails are protected.
I hope you can help me with this problem for I don't like having my
computer unprotected and I paid for it.
Thank you very much in advance.
Kind regards,
Myriam Engelen
Hello, I tried three times to login to safe mode (F8 button) but I got no list I could select the safe mode. Apparently this is not working on my laptop? I removed AVG Antivirus again for about the fifth time now in order to have access to internet again. Although, I'm still protected by AVG while surfing.
As this problem still persists, is there something else I could try? Thanks.
Hello, I reinstalled AVG but couldn't follow the instructions. So, as it becomes to difficult for me and takes too much time I decided to leave it as it is without AVG. Thank you all for the efforts you made.
Hello Myriam, I apologize for the inconvenience caused. Kindly let us know the name of all AVG programs installed in the computer and the name of 'Operating System' installed in the computer in which you are experiencing the issue. Also please let us know if you are able to access other 'Web Browsers' like 'Google Chrome' and 'Mozilla Firefox' ? Thank you.
I had a computer crash in Windows on which AVG (paid licence) was installed. I recently tried to reinstall AVG on another computer. The installation was succesfull but I could not have access to Windows Internet Explorer anymore. I got the message " Internet Explorer is not responding".So I did a system repair in order to undo the installation of AVG and to have access to internet again. I already tried to do a reset of internet explorer but no result. Does anyone have an idea how this problem could be solved?
Hello, sorry but I don't understand the question. What do you mean by "login to safe mode?" Thank you.
Hello Myriam. Did you disable AVG temporarily and check if you could access internet? Please have a look at http://support.avg.com/SupportArticleView?urlname=How-to-disable-AVG to disable AVG temporarily. Please contact us back should you need any further assistance. Thank you.
Hello,
As I already mentioned, I had to uninstall AVG in order to have access to the internet again. So yes, I have access to internet when AVG is removed. What should I do now or could it be a compatibility problem?
Myriam, Have a look @ this article (http://avgclick.me/rebootintosafemode).
Hello,
to internet.
Kind regards,
Myriam Engelen
Hello Myriam. I kindly request you to login to safe mode and check whether you can get connected to the internet when the AVG Antivirus is enabled. Thank you.
Hello,
