Problem with AGV VPN Secure
Hello, I have problems with AVG VPN Secure, when I want to change email I am forced to disable the VPN, my emails are from the French operator Orange, otherwise impossible. Do you have a solution? Thank you in advance
Hello Jean,
We are really sorry to know that you are facing issues with AVG Secure VPN.
We apologies for the inconvenience caused. We'll certainly check and help you out.
Mostly, this might be due to heavy network traffic, in that case reconnecting/changing the VPN location may solve this issue. Please try to connect to different server location and check.
To change the location you can refer this article: https://support.avast.com/en-us/article/use-secureline-vpn/#pc
Could you please let us know how long you are facing the issue?
Could you please share us the screenshot of the page (https://support.avg.com/SupportArticleView?urlname=AVG-Create-screenshot)
Thanks in advance.
Hello Jean,
Thanks in advance.
