Problem with avg driver updates
Hello Frede,
We are sorry to know that the AVG scan is stuck in scanning for "Windows update" This issue can happen if the "Windows Update server is not responding or a very large file being updated that is taking time". To fix this issue, we suggest you to manually run windows updates from your computer and make sure no further windows update available. After which you can run AVG Driver Updater scan and see if that fix the issue.
Thank you
Hello Frede,
Thank you
has any one had this problem that i am having ?i start the program and it dose the searches until it gets to the windows update bit then it gets stuck i have let it run for 24hrs just in case  but it is still running now i know that windows on my pc is up to date as it has a windows update program installed .I am running windows 7 home premium service pack 1. Would this be the problem?if so how do i fix it our have i just wasted £20 on this program
