Hello Roman,
You've reached the AVG community support forum.
We regret the inconvenience this has caused you. Our team is already aware of the issue and our team has fixed the technical issue and you can connect to VPN again. but if the issue persists. Please follow the below instructions:
1. Open AVG Secure VPN and go to Menu and choose Settings.
2. Select "VPN Protocols".
3. Then select Mimic or OpenVPN protocols
4. After changing the protocol to mimic, try enabling the VPN to connect with the server.
Been requested to contact you. You have found something. Code MRGK3M. Will not connect. Thank you,
Hello Roman,
