my avg free edition got problem. i try to uninstall this error come out 0xE001003D. when i try to repair this error come out 0xE0010002…what should i do?
Hello Azhil,
We regret for the inconvenience you are facing with installing the AVG program. Please check whether you have installed any other conflicting applications like McAfee, Avast, Norton etc… on your PC, If so please uninstall the conflicting applications.
If not, please follow the instructions on the article http://support.avg.com/SupportArticleView?urlname=How-to-reinstall-AVG to reinstall all the traces of the AVG program and check whether it resolves the issue.
Hello Azhil,
You are most welcome, Azli,
We are glad to know that your issue was resolved after following the remover tool instructions.
Hi Kishore…
thanks for your help…i successfully uninstall avg by using the remover tool, and then install back avg…problem solved…
thanks again…
