Windows 8.1
I tried to comment 3 times already and the pic is not visible.
Windows 8.1
Hello Ann,
We are sorry for the inconvenience caused. We will check and help you to resolve it. Could you please share the screenshot of the AVG which shows it using high memory? Also, please confirm the operating system installed in your device.
Hello Ann,
I have a problem with avgbidsagent.exe. I think this is quite a new problem, I'm using AVG since I don't even remember when, but in the last days, or even weeks this process takes so much memory - right now 662 MB. Why?
What I can do about it? I'm not sure what this process is really doing, but can I just stop it? There is no option to stop it really, the access is denied, but before trying some kind of method from the internet I want to be sure - can I delete this file and or stop this process, or not?
And is it normal that it takes so much memory?
Please accept our apologies for the inconvenience this has caused.
To further investigate this issue & help you resolve it, we've sent you an email with detailed instructions to contact our additional support team.
Please check your inbox/spam folders to find the email and use it to contact them.
Thank You all for the answers. It helped! But now - you can see on the screenshot above - "AVG service" takes 492 MB of memory. I'm not scanning right now or anything. This process never took so much before.
Thank you for providing the required screenshots, Ann.
We will certainly check and help you.
Please repair the AVG Internet Security program and check if that helps.
Please refer to the steps in the below article to repair AVG Internet Security.
https://support.avg.com/SupportArticleView?urlname=Repair-AVG-Antivirus
After repairing the program, please reboot the PC once to apply the changes.
Hello Ann,
We are sorry to know that you are unable to share the pictures. Could you please check and confirm whether you can see changes in CPU usage after the repair of AVG Internet Security? We look forward for your response.
