Hello Henriette,
I see that you have posted another query with same description. It is recommended to post your query on single post to avoid confusion and speed up the resolution. I suggest you to check the answer in your initial post.
We appreciate your patience and understanding.
I have a problem in finding latest order history as I want a refund. Where will I find it?
Hello Henriette,
