Problem with installation
Peter, Did you comply fully with this link (https://support.avg.com/answers?id=906b00000008mmVAAQ)?.
For a while the updates were not installed because 'there was already another installation going on'.
I tried te remove this ongoing update but it didn't help.
​Then I tried to remove the installation as a whole. That didn't work either because another ongoing installation.
in the end I used the AVG removal tool and succeeded​ te remove AVG.
But when I tried te reinstall AVG it was refused because there was still another installation going on.
Is this a catch 22 situation?​
Hello Alan,
I have tried the removal tool. When ​I try to reinstall AVG it keeps on saying that the installation failed.
It shows an error code 0xc0070652​
Hello Peter,
I apologize for the inconvenience caused. I have sent you an email with necessary steps to fix this issue.
