Hello Abu,
We apologize for the inconvenience. We suggest you to check if the traces of AVG is till present in your computer. And remove the same. Please use the AVG remover tool again and once the remover gets complete, go to C Drive and remove the "AVG Remover" folder. Use this link to install AVG Free http://files-download.avg.com/inst/mp/AVG_Protection_Free_698.exe
Feel free to contact us for further query.
Yeeayy, finally its installed
What i do is delete all registry belonging to AVG + running AVG remover, and its work
Thanks for solution
Hello Abu,
Thank you for your kind post and for your support of AVG products. That's great to hear your issue has been resolved now. If you are facing any further issues with AVG program please let us know and we are happy to assist you.
Thanks for solution
Hi, I already used AVG for 2 years, but recently because of my laptop laggy with WIndows 10, i reset this PC. (So all of program is erased)
but when I tried to install AVG Zen after reset, its shows endless process (roughly 3 hours).
and when i tried to install AVG AntiVirus Free, its cannot finished with error code: 0xC0070643
So i use AVG_BFEfix.exe and AVG_Remover.exe as mentioned in the other forum, but when tried to install AVG AntiVIrus Free again, its says error code: 0xE001D012
What should i do? i already have trust with AVG and do not want to install other Antivirus than AVG ![]()
please hellppppp
