Problem with loggin in to IneDrive
Hi Tor,
If you suspect that AVG is blocking the access, we'd initially suggest you to disable AVG protection temporarily & check.
I have suddenly got a problem with OneDrive and wonder if it may is connected to AVG in any way. I can't log on OneDrive and get the error code 0x8004de40 from OneDrive.
Have you experienced this problem before? How do I solve it?
Regards,
Tor Danielsen
Hello Tor,
Thank you for your efforts and understanding.
Please let us know if you have any concern with AVG and we will help you.
Hi Tor,
No, that didn't seem to make any difference. Thanks anyway!
Regnards,
TorD.
