Problem with menu
Hello Bill,
If we understand correctly, you are unable to locate 'Settings' option in Menu tab of AVG Free Antivirus window. Are we correct?
hi,download and install AVG 2017 free,click menu in the right but not show the settings,can fix this?
Bill,
We regret for the inconvenience caused. We request you to repair the AVG Free Antivirus program by following the instructions below and check if Settings option works fine. Here are the instructions:
1. Go to Start -> Control Panel.
2. Open (Programs) -> Programs and Features, or Add or Remove Programs.
3. Select AVG Protection in the list of programs.
4. Click the Change or Change/Remove button.
5. Select Repair.
Please feel free to contact us for further assistance regarding AVG.
yes,i click in menu but nothing,how to fix this?
