Problem with Outlook... because of AVG?
For a few hours now, I am unable to use Outlook properly. A never-ending file keep it from running properly. The file is called:
pmcdn.avast.com/images/icons/icon-envelope-tick-round-green-avg-v1.png
Since "AVG" was in the name, I was wondering if other AVG customers have had the same problem and, more important, how do I get rid of it?
Hi Midhun,
This is very weird because I shut the computer down for the evening and when I came back, Outlook was working fine again. Still, it could happen again, right?
What happened is that Outlook simply wouldn’t open.  It would download, or try to locate, or contacting that famous file.
This is what I mean: I let it roll for 2 hours and nothing moved:
User-added image
By the way « en cours » means “in process” . French computer, yes. J
If you can help, in case this happens again, I would be very grateful.
Thanks,
Donald.
Hello Donald,
We're sorry for the inconvenience this has caused you.
Could you elaborate what exactly happens when you try to access Outlook?
Do you receive any thrat/error message from AVG?
Do you access Outlook via browser or the Outlook program?
Have you tried temporarily disabling your AVG Internet Security & checked for this issue?
If you haven't, please refer to this article & temporarily disable your AVG Internet Security.
Keep us updated.
Hi Donald,
You are most welcome.
We are glad to know that your issue has been resolved. Feel free to contact us for any other assistance with AVG.
Excellent, thank you for the information. Hopefully it will not happen again but if it does, I will  know what to do!
The AVG Support Community is awsome. :slight_smile:
Thanks again,
Donald.
Thank you for sharing us the screenshot, which provided a better clarity, Donald.
From your description, it seems that AVG program is set to add a signature at the end of emails & Outlook seems to be stuck in the process of loading that file.
If this issue re-occurs, please : Open AVG program - Menu - Settings - Basic protection (left pane) - Email shield - Disable 'Add signature at end of emails' & then reopen Outlook to check.
Additionally, you can try repairing AVG program once to ensure that all the services are running fine & latest version is installed.
