Problem with updating AVG Anitviurs PRO for Android mobile
I can not update my current application AVG Anitivirus PRO version 5.1.1.221227 originally installed in my currently bough new smartfone Alcatel Pixi 4 /6/ model 9001 with Andorid 6.0.1 into AVG Antivirus 2017 through Google Store. After many trials – when downloaded the newest version and the installation is started there is always error code 504  “the application can not be installed”.
All remaining applications are updated without any problem.
Would appreciate your help how to fix this issue.
Thanks and best regards,
Ewa
Ewa,
We are sorry to hear about the inconvenience caused. We request you to contact our android mobile support team as this community deals with the technical issues with AVG Windows products and Android support is provided through email only.
Please click on the following link( http://avgclick.me/AVGtechnical ) select as Android, fill out your details and click email option. The AVG mobile team will reply back to you via email with a resolution. Thank you.
