Ivan, This Community is basically English language… Query translation…
theft problem
Hello, I activate the theft protection avg but I have lost the password and can not be changed so the telefone block is how to do ???
Don't know if this will help?.. Have a look @ this article (http://avgclick.me/LockedPhone). Otherwise, Please click on the following link (http://avgclick.me/AVGtechnical) and fill out your details, select as Android then the name of AVG Program that you installed in your mobile and in description please completely explain about your issue and finally click on Email option. The AVG mobile team will reply back to you via email with a resolution.
Bonjour, j'ai activer la protection antivol de avg mais j' ai perdue le mot de passe et impossible de le changer donc le telefone est bloquer comment faire???
theft problem
