Problème de connexion
Hi Dominique,
The support available here is in English currently. You can for example use Google translator for translation purpose.
We're glad to look into this & help you. Sometimes, this might happen if there are any conflicting programs installed on your computer.
In this regard, please check & disable if there are any other VPN service enabled.
If not, please try reinstalling AVG Secure VPN & check if it helps. We've sent you an email including the activation code. Reason being, privacy concerns.
Depuis plusieurs semaines, le VPN ne se connecte pas. Explication donnée "Problème technique". De mon côté, j'ai vérifié, mon internet fonctionne correctement.
Merci pour votre réponse
Hi Dominique,
