Problems after update
After a recent update, i cannot print from adobe reader or scan a document at my printer anymore. What could be the main course of this? Severall collegues have the same problem. But when i am logging in on a different account on the same computer, the problems are gone. The problem seems to be connected with the account on wich the AVG update is done.
Hi Javier,
Did you try temporarily disabling AVG to see if it helps on this issue?
Hi Javier,
