Problems booting in to PC os
Hello Les,
We understand your concern. In this case, we suggest you to click on "Remove AVG using Clear tool" in the reboot option and then check if you still get this message after another restart.
Thank you
https://support.avg.com/answers?dt=login#!/feedtype=SINGLE_QUESTION_DETAIL&dc=All&criteria=ALLQUESTIONS&id=906b0000000DiatAAC
Hi AGV I had the same problem as the gentleman on the above link so I followed the advice given on the link and downloaded the AGV removal tool and the Clear exe
I ran both tools and now every time i start my PC a page comes up saying boot in to remove AGV or Windows 7 and I have to pick which one rather than it just booting normally into windows 7…
Can you help/advise please?
Thank you in advance for your help?
Hello Les,
Thank you
