Hello Trine,
We apologize for the inconvenience caused. Did you use 'AVG Remover Tool' to remove AVG traces and then tried reinstalling? Are you trying to install a paid or free version of AVG program? Thank you.
Hi there!
Having problems downloading AVG, and get this error code: 0xc0070643
After a windows 10 update, suddenly my AVG wouldent work anymore!
Please help me ![]()
Hello Trine,
Hello Trine,
We are sorry to know that the issue persists even after using "AVG Remover Tool". We appreciate your efforts to resolve the issue. I have just sent you an email with the instructions to get connected with our senior technical support team. Please follow the email instructions to get additional support to resolve the issue. Thank you.
Hi!
Thanks for answer ![]()
I have used the removel tool, without any luck ![]()
I have the free one.
trine
