Hello Chris,
We request you to try using our AVG remover tool once and then try installing the AVG Protection.
To download the AVG remover tool please click on this link: http://aa-download.avg.com/filedir/util/AVG_Remover.exe
3) Your computer will be restarted automatically. After the restart, AVG Remover will finish the uninstallation.
To download, install and activate AVG Protection program please follow the instructions mentioned in the following article: http://avgread.me/1FKGRZI .
Hi! Just paid for AVG Protection Pro - gone through the installation but on reboot all I get is the free trial version again! I have removed all previous AVG software from the system. Please can someone help - 3 hours spent on this and all should have happened at the click of a button…
Hello Chris,
