Hello Deivid,
May I know for which AVG program you are getting the installation issue?
Is it free, trial or paid version?
May I know the exact error code that you receive for the AVG installation?
Did you use this remover tool http://aa-download.avg.com/filedir/util/AVG_Remover.exe ?
Hello? I have tried several times using AVG remover and tried all your advice but still my avg is not installing it gets to 75% and stops
To install AVG Antivirus Free 2016 we request you to use the offline installation. To determine whether your OS is a 32-bit or 64-bit, please click on this link. http://support.microsoft.com/en-us/kb/827218
For 32 Bit : http://files-download.avg.com/inst/mp/AVG_Antivirus_Free_x86_694.exe
For 64 Bit : http://files-download.avg.com/inst/mp/AVG_Antivirus_Free_x64_693.exe
Hello Deivid,
We regret for the inconvenience caused.
We request you to run AVG remover tool using the following link and the steps and let us know whether you are facing the same issue.
To run AVG remover tool follow the below steps :
Please click on the below link to download remover tool
Accept the license agreement and then choose AVG Product and remove it.
Hello Deivid,
