Hello,
In November and December 2016 we had the same issue, after downloading the latest version of Photoshop. This version together with our AVG internet security subscription gave us many problems (mainly not being able to open gmail, Google analytics, etc), so that we decided to stop our Adobe subscription (although we still had to pay half a year).
But now we really want Adobe Photoshop back. So the question is: is the issue solved? Can we buy a Photoshop subscribtion again?
Mariette
I think sometimes AVG gives issue with Lightroom
Hello David,
We request you to check whether you can access your Photoshop application while AVG is disabled.
Please use the below link to disable AVG:
http://support.avg.com/SupportArticleView?urlname=How-to-disable-AVG
Please let us know the status once you have disabled the AVG program.
Ranjani Bakthavachalam,
So, I will give the path above a shot, as soon as I figure out what to do from my new current situation.
I went to lavasoft and downloaded ad-aware. as Ad aware finished I received a win32/Zperm virus alert from AVG. Now I feel like I may be in even hotter water. Can AVG handle this? for now I will click protect me and hope for the best.
Hi Karthikeyan,
I would like to share that your method of resolving the bug has worked for me. My Win10 was affected by the "multiple-processes-for-console-based-script-host". The internet connection became partly dysfunctional and would only connect to google based websites. Looking back the Problems only started when Adobe CC updated Photoshop. Since AVG is always running on my machine, I can only assume that this bug may have occurred in this correlation. Will there be a fix for this issue? Understandably I’d rather avoid reinstalling all this software after every adobe update. Or is there a manual solution (like turning off the firewall before the update)?
January 28, 2017 - the problem still exists. A possible solution has been posted by Adobe here:
https://forums.adobe.com/thread/2234816
I have made the registry hack and so far it seems to have resolved the problem. YMMV. I sure wish AVG and Adobe could get their heads together and permanently resolve this problem. Very disappointed and frustrated.
Hi Karthikeyan,
I have just subscribed to Adobe CC (photographic). I installed the CC app which automatically downloads and installs Lightroom without issue. As soon as I installed Photoshop my browser locked up and I was unable to go online or even sustain an existing connection. The situation appears to be described here: Redirecting
Most of the suggestions made here are a bit outside my comfort zone. I note that one contributor seems to have made a case for assigning the blame to an AVG product. If this is indeed a conflict between two popular families of software then it would seem likely that other AVG users have encountered similar difficulties. Has anyone found a fix fit for the uninitiated?
FWIW I am using AVG Internet Security.
Hello David,
Thank you for your kind post and for your support of AVG products. That's great to hear your issue has been resolved now. If you are facing any further issues with AVG program please let us know and we are happy to assist you.
Hello,
Mariette
The issue was not corrected with the suggested actions. I tried multiple attempts but cannot wait any longer to resolve this issue through AVG. Perhaps someone else will find guidance through this discussion thread. I am respectfully removing AVG from my desktop, laptop, game pc, and 3 android devices. I am going to try bit defender since I just subscribed for a year since this issue started. If Bit defender fails, I shall entertain returning to AVG services as I have enjoyed them for the past 2 years.
Thank you
Hello Siva,
Thank you for contacting AVG Community Support,
We apologize for the trouble caused. We'll check and assist you.
If you have any concerns regarding AVG, please write back to us in a separate private post, so that we can check and assist you accordingly.
Thank you in advance!
Hello Willie,
Please uninstall all AmtiVirus apps from your computer and update Windows and reinstall Adobe CC (including apps) and then install AVG back. Once this is done, please check if the issue gets resolved.
Thank you
Hello David,
Just to clarify, the issue was not access to Photoshop but access to the web via a browser together with a vast number of M'soft Console scripts showing up in task manager - I wouldn't know the nature of any connection!
However, I tried your suggestion and disabled AVG. I also turned off the Firewall - I don't know if that was implied. I then went direct to Adobe, downloaded and installed Photoshop and paused for five minutes. No scripts showing up. Visited AVG via browser - no problems. Turned everything back on. Have since restarted a couple of times and all seems fine. I think you have solved my problem - Thanks!
IIRC ten years ago "May need to disable antivirus while installing software" was a familiar concept but this is the first time I have needed to do so and sure enough - I'd forgotten.
If you would like to be extra helpful a brief comment on whether I was correct to turn off the firewall as well would be appreciated. Thanks agin.
Hello Mariette,
We can understand your concern. AVG 2017 version has released with updated version with new interface also with fixes for most of the issues. Please install our AVG 2017 version and let us know whether your issue as resolved.
We are glad to know that the suggestion provided worked out but do you mean that you still face the issue when AVG Firewall is turned on?
