Hello Eduardo,
We regret for the inconvenience caused. We have a small technical issues on our server side and our developers are working with high priority. The issues will be fixed as soon as possible.
Hello, i have exactly the same issue and i need to find my phone. Any clue on when it will be fixed?
Hello. I can login to my account but it fails with anti-theft. I even reset my password but i didn´t work for anti theft. Any ideas?
Hello. same as Eduardo, I can login to my account as login to this forum but it fails with anti-theft. I even reset my password many time but it didn´t work for anti theft at all.
Please help.
Hello Gavin,
Our customers are facing issues in logging in to their account in AVG Mobilation website. It is a known issue and has already been escalated to our senior technicians and they are working on it. Unfortunately there is no time frame on when it will be fixed, however the issue has been given 'high priority' and so should be fixed soon. Thank you.
My order number: GPA.1350-8167-4086-46438
Date of order: 17-06-2016 12:58:24 ICT
Please kindly solve my problem because I purchase your app just use this anti theft feature.
looking forward to your soon fix.
Best regards,
Hello Eduardo,
Hello Tabby,
As we have mentioned before, It is a known issue and has already been escalated to our senior technicians and they are still working on it. Unfortunately there is no time frame on when it will be fixed, however the issue has been given 'high priority' and will be fixed soon.
I also have the same issue, any updates?
